2000 Other Chevrolet Models Power Steering Pressure hose fit
2000 CHEVROLET
92,000 MILES • V8 • 4WD • MANUAL
LUNARMER
Is there a replacement fitting for the pressure hose fitting to the reservoir that the pressure cutout switch to the AC is available? Where could this be purchased?
I've been told that this fitting is worn and leaking and they are no longer made.
Oct 12, 2010 at 1:36 PM
BMRFIXIT
  • 19,053 POSTS
Can you elaborate as to what do you have for vehicle model year and engine size most Chevy power steering high pressure hose connected to the rear of the P/S pump and to the gear box if its the fitting at the pump side that need to be replace its a part of the pump
https://www.2carpros.com/forum/automotive_pictures/99387_getimage_7.jpg
Oct 12, 2010 at 8:05 PM
LUNARMER
2000 Chevy K-2500 ,350 CID , 5 sp- transmission, VIN-1GCGK24R0YF483088 At the point of connection to the power steering pump is there a replacement fitting for the connection to the pump and is there a replacement part Available for this connection? Photo's Attached
https://www.2carpros.com/forum/automotive_pictures/582375_2000_HD_Chevy_Winchester_KY_001_1.jpg
https://www.2carpros.com/forum/automotive_pictures/582375_2000_HD_Chevy_Winchester_KY_002_1.jpg
Oct 13, 2010 at 7:46 PM
BMRFIXIT
  • 19,053 POSTS
Its a part of the pump for under $ 40 you can have the pump as a whole
https://www.2carpros.com/forum/automotive_pictures/99387_1_16.jpg
Oct 13, 2010 at 8:58 PM
LUNARMER
Mo it's not part of the pump. It is a retrofit item that replaces the items shown in the photograph and is available from a Chevrolet certified parts supplier for about $77.00.
I found this information after I requested the information from you and the answer didn,t fit the problem. The fitting I was inquiring about does not come with a new pump.
Thank You
Oct 14, 2010 at 10:00 PM
BMRFIXIT
  • 19,053 POSTS
thanks for the update
good luck
Oct 15, 2010 at 11:52 AM
