1998 Other Chevrolet Models truck turns over but won't start
1998 CHEVROLET
105,000 MILES • V8 • 4WD • AUTOMATIC
JEFFELECTRIC
  • 12 POSTS
I have a chevrolet K1500 4 wheel drive pick-up with a 5.7 engine. Once in a while when I took the truck for a ride, when I returned back home in a while I would try to start the truck again but it would just turn over but not start. This started happening more often until now the truck won't start at all. I changed the fuel pressure switch, the fuel pump relay and the complete full pump assy. Even though I was getting spark I changed the cap and rotor anyway, I also checked the crank pos. sencer and it was ok. When I put gas into the throttle body the truck will run until the gas runs out of the throttle body. I have also changed the fuel filter. I don't know where to go from here.
Jul 30, 2010 at 8:55 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Is there anyway you could rent a code reader and see if you have any code's?Also have you checked your fuel pressure yet or have you checked to see if your injector's are pulsing?
Jul 30, 2010 at 9:09 PM
JEFFELECTRIC
  • 12 POSTS
Hi Louie, My codes are clear and the fuel pump is putting out 64 psi. I would have to take off the top intake manfold to get at the fuel injectors. This truck has Central Sequential Fuel Injection ( Central SFI System ). Is it possible that the injectors are not getting the gas to them?
Thanks
Jul 31, 2010 at 4:03 PM
SATURNTECH9
  • 30,869 POSTS
[quote:78e714f442="jeffelectric"]Hi Louie, My codes are clear and the fuel pump is putting out 64 psi. I would have to take off the top intake manfold to get at the fuel injectors. This truck has Central Sequential Fuel Injection ( Central SFI System ). Is it possible that the injectors are not getting the gas to them?
Your fuel pressure sounds good so you didn't have any code's if you did what were they?Because you said your code's were clear.I think your injectors just aren't sending the fuel to the cylinder's.What is your 8th digit of vin i'm having trouble finding the central sequential injection diagnoses for your truck.
Thanks[/quote:78e714f442]
Jul 31, 2010 at 7:51 PM
JEFFELECTRIC
  • 12 POSTS
The 8th diget is R.
Aug 1, 2010 at 11:07 AM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1998_chevy_pick_up_cranks_but_wont_start_part1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_1998_chevy_pick_up_cranks_but_wont_start_part2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_1998_chevy_pick_up_cranks_but_wont_start_part3_1.jpg
Alright follow the crank but won't run trouble tree it will bring you to testing the fuel system.Let me know what you find.
Aug 2, 2010 at 12:57 AM
JEFFELECTRIC
  • 12 POSTS
The wiring diagrams that you e-mailed were were blurry and could not read them even at the small print. Would it be possible to send them at a larger format.
Thanks
Aug 2, 2010 at 9:10 AM
SATURNTECH9
  • 30,869 POSTS
I emailed it all to you that should help.
Aug 2, 2010 at 11:40 AM
JIMMY LAIRSEY
Crankcase position sensor little brass looking sensor on the bottom of engine right on the side of the crankshaft if gets oily from a leak it will go out and it won't crank at all.
Dec 22, 2021 at 7:12 AM
