1996 Other Chevrolet Models shifting
1996 CHEVROLET
194,000 MILES • V8 • 2WD • AUTOMATIC
RONALD CARTER
my 96 chev 1500. 5.7 eng. The tach and speedometer will quit working. When this happens, the truck will not shift into OD. If I stop pull over and restart the truck, most times it will work. IF I see the tach isn't working, I know the truck will not shift into OD. I know my transmission is the electronic type. Is there a part I can replace? Sensor etc. etc. Fluid is clean and smells good. No slippage. Thanks for the help.
Feb 19, 2009 at 12:01 PM
BILLYMAC
  • 2,204 POSTS
hi you can replace the speed sensor and the trans computer good luck billymac
Feb 20, 2009 at 11:35 AM
