1995 Other Chevrolet Models changed to an automatic Transmis
1995 CHEVROLET
190,000 MILES • 6 CYL • 2WD • MANUAL
FD1967
I was in a major financial bind, so I got a good Automatic and put in this truck, I did not realize that the sensor for the speedometer was all electronic on the 1995, all works well except for the speedometer, is there a remedy for changing the old speedometer cable over to the electronic so that the speedometer works and the PCM reads all correctly?
Sep 6, 2010 at 7:59 PM
HMAC300
  • 48,601 POSTS
first thing you'll have to change to a speed sensor which i'm not sure if you can get one or not. It depends what transmission youput in. If you put a 700R4 in you might something similar with a 4L60. that may be your cure. the other problem you runinto is you went from manual to automatic and the PCM will never be right because it will always think it's a stick and not an automatic. You are also missing a complete wireing harness that hooks to a 4L60 so don't change the PCM to an automatic thinking that will help. Knowing what type of an Automatic would help tremendously. Youmight be able to use your old speed sensor so don't throw it away until you check other things out.
Sep 14, 2010 at 5:39 PM
