1994 Other Chevrolet Models 7 fuses blown
1994 CHEVROLET
JAMTECH
Electrical problem
1994 Other Chevrolet Models V8 Four Wheel Drive Automatic
a fuse blown for the parking lights and the dashboard lights that light up the guages. i replaced it 7 times within 10 mins all blown i replaced it with several diffent higher amps. what should i do and where?
Feb 14, 2009 at 8:58 AM
JDL
  • 16,098 POSTS
Hello, don't use a higher rated fuse. What is the model of your vehicle? Does the fuse blow only after you turn on the headlite switch? You could probably use a testlite on the fuse terminals instead of blowing all your fuses. If the testlite lites-up, the circuit is going to ground somewhere.
Feb 14, 2009 at 9:15 AM
JAMTECH
1994 chevy k1500 305 v8. blows out after about 5 mins or 1min after turn on the lights.
Feb 14, 2009 at 12:56 PM
JDL
  • 16,098 POSTS
I divide the headlite switch into two circuits, a circuit breaker for the headlamps, and fuse circuit for the dash lites--tail lites, whatever. I usually suspect the longest circuit first, brown wire from the headlite switch to the tail lites.
I fixed a problem similar to this a few weeks. A GM vehicle, different year and model than yours. It was dead short to ground on that brown wire circuit that goes to the tail lites. It would blow the fuse just as soon as you turned on the headlite switch. I took the connector loose at the headlite switch and at the rear, then used a testlite connected to voltage, touched it to the brown wire, the lite came on. So I knew where the short was, it didn't blow the fuse because the testlite controlled the load on the circuit. I can't say if you have the same problem.
Feb 14, 2009 at 2:07 PM
