Hello swacky
Thanks for getting back with me
Yes, I understand that is the first thing you did but I need to know the results of when you do that..such as, the car sputtered, tried to start, engine just rotated and no difference
Those things are clues that I need
If you are getting a good spark from all the plugs not just one then we know the electrical as far as the spark is concerned is okay
If you spray starting fluid in it and it sputters it may be the fuel pump is not working. What is your fuel pressure?
If we are getting a good spark on everything, if we have good fuel pressure, then the next thing to check is the compression.do you have good compression on all the cylinders
But that is what we need to figure out
Also, are you sure about your model and engine size of car? I show the Lumina either has the 4cyl, 2.5L, or the 6 cylinder 3.1L VIN T, or 3.4L VIN X.
Now based off of the 8th digit of the VIN you gave me, L, you have a 3.1L..is this what you have?
Mar 8, 2009 at 1:37 PM
