1992 Other Chevrolet Models 92 S-10 Blazer
1992 CHEVROLET
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANTDELAROSA
Hello. I recently purchased a 92 s-10 blazer and have had problems since the get go. Most have been hashed out but 1. For some reason when the car is at a stop, whether it be in drive, park or reverse, the car will stutter or stall causing the car to shake. Sometimes the car will shut off. When I start the car again, it works as normal. Also when driving I will feel the car lose a little power, I don't lose speed, and pick up again. I'm not sure what it could be. I have replaced the spark plugs, wires, belts and air intake control valve but have not been able to solve this issue. Thanks for your time and patience reading this question(s).
Feb 3, 2010 at 12:59 PM
In the early 90's, the most common problem with the 4.3L V6 was the intake gasket. Have you checked for vacuum leaks around it? Check closely around the rear of the intake. Also, has the check engine light been on? Have you checked fuel pump pressure? And finally, if everything else checks out fine, you'll need to check the catylatic converter to see if it is plugged at all. Have you ever heard a rattle from the exhaust? If so, the inside of the converter could be loose and causing a random problem.
Let me know what you find.
Feb 3, 2010 at 1:39 PM
ANTDELAROSA
Thanks for the quick response. This may sound silly but can you tell me or point me in the right direction for the intake gasket. I will check there first. The check engine light did come on once but after I tested the air intake control valve and it was replaced with no further light indicators. I have not checked fuel pressure but that can be done (by me hopefully). How can I check the catalytic converter? Is it a visual check or a test that can be run? Finally I will listen for any rattle from the exhaust. Just to add on the stalling seems to be cyclical, it's never random it always sputters after the same amount of time.
Feb 3, 2010 at 1:50 PM
We are here to help, so don't feel funny asking any questions. The intake manifold is located on the top of the engine. It bolts to the engine block. Also, the throttle body is bolted to the top of it. If you look straight down at the top of the engine, you will see a large aluminum part that bolts at each side of the engine. That is the intake. If you are still unsure, let me know and I will try to dig up some pictures.
As far as the converter, with the engine running, listen for ratteling, hissing... sounds coming from that area. Also, check the exhause to make sure there is a good amount of pressure coming from it.
As far as a visual inspection, when a converter is plugged, it will get so hot when the engine is running that it will turn red hot. If you look at it (after driving) with the engine still running and it is glowing red hot, chances are it is plugged.
Let me know what you find and if you have other questions. Remember, the only dumb question is one that is not asked, so please feel free to ask anything.
Feb 3, 2010 at 7:48 PM
ANTDELAROSA
Sorry I have not been able to get back to you promptly. I have recently replaced the fuel pump and battery because both gave out and am replacing the oil ignition switch due to a leak. I thought after replacing the fuel pump the blazer would perform better but it has not. As to your previous suggestions here is what I have done. I checked the catalytic converter and it was hot to the touch. Today I will check for rattling or hissing. About the exhaust pressure, how can I measure the pressure myself? Will the pressure or lack thereof be obvious? Lastly I will look for some air pressure leaks from the intake manifold. Thanks for your help.
May 4, 2010 at 11:36 AM
To properly test catalytic converter pressure, you need a pressure gauge and to remove the up and down stream O2 sensors. Just see if you hear any ratteling or if the converter appears red hot after driving or if you hear a whisteling or there is little pressure coming from the exhaust.
May 4, 2010 at 12:07 PM
