Can putting on the wrong oil filter, although it fit, cause it to blow off?
Feb 17, 2009 at 1:49 PM
BOWTIE BABY
MEMBER
Yes, all filters are different in a few ways, the thread size and thread count. If you have a chevy V8 it should be a fram ph5, double check that part number before you get 1.
Feb 19, 2009 at 12:21 AM
AMORRISON
MEMBER
Thanks. Would it blow off immediately or at least leak prior to it blowing off?
Feb 19, 2009 at 1:02 PM
BOWTIE BABY
MEMBER
It depends on how different the filter was from the correct 1. Get the correct filter and install it. Is your filter mount clean and free of old gasket? Filters can also loosen up and eventually come off if you dont tighten them enough. Make sure you tighten it by hand but the filter says one quarter turn after contact. Go tighter than that or it will leak.
