1986 Other Chevrolet Models HORN RELAY
1986 CHEVROLET
GOLDWING
Electrical problem
1986 Other Chevrolet Models 6 cyl Two Wheel Drive Automatic
Where is the horn relay on an 86 chevy el camino. How can you tell when it is bad.
Thank you
Frank
Jul 5, 2008 at 1:14 PM
KLSHIEL
  • 163 POSTS
I don't know where the relay is but you should be able to follow the wires from under you dash. The best way to test it is with a volt meter. Test and see if power is getting to the relay(someone needs to hold the horn). If it is you should be able to hear the relay click when power is applied. To be sure you can test if power is coming out of the relay. Before you do any of that you should check the switch in the steering wheel. I know the ones in the '80's camaros went bad often. That is something you can safely bypass with a screwdriver.
Jul 15, 2008 at 3:49 PM
