1962 Other Chevrolet Models trans lube on 1948 fleetline
1962 CHEVROLET
80,000 MILES • 6 CYL • 2WD • MANUAL
HUGGINS49
I was seeking info on chrcking / changing the trans oil and needed to know where it goes in the trans.
NOTE: this is a 1948 NOT 1962, Mike told me to do it this way or it would not submit. thanks
Sep 14, 2010 at 1:49 PM
HMAC300
  • 48,601 POSTS
i'm assuming this is a stick shift trans. There should be 2 plugs on it, both under the car. One will be on the very bottom and that is the drain. There will be another one on the side which is the fill. You can use any grade of 80w/90w gear oil incuding synthetic. todays oil is much better thatn the stuff they used then. Fill the trans until you can feel the oil with the first knuckle of your baby finger in the fill hole. In other words if you tip of your finger gets oil then it's full.
Sep 14, 2010 at 5:33 PM
