1960 Other Chevrolet Models rear
1960 CHEVROLET
11,570 MILES • V8 • 2WD • AUTOMATIC
ZATHERA
I have a GM D106 370 7306 /10 bolt rear. 37-10 it is connected to a 350 turbo trans. Need to change to a highway gear. What year is this? what do I look for?
Aug 28, 2009 at 1:29 PM
HMAC300
  • 48,601 POSTS
If you have a 10 bolt rear end with a 3:70 ratio the lowest you'll be able to go is 3:08 or maybe a 2:93 ratio without changing the diff case. If this car is not stock which it sounds like you can also put in an overdrive transmission which will more thatn likely do what you want.
Sep 16, 2009 at 11:45 AM
