Idle speed increasing
2004 CHEVROLET OPTRA
YOGESHKOSHTI
I have purchased a 2nd hand chevy optra 2004, it is running fine but sometimes when I turn on AC the RPM raises too high (3500RPM) and won't come to normal position, even I turn off the AC still the idling is too high....I don't know how to set the RPM of it.
It is creating a problem for me while going for a drive.
Can you please suggest me how to set the idle time for my car?
Thanks in Advance!
Yogesh
Jun 14, 2010 at 12:29 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I would service the throttle body. I have attached two pictures and a tutorial for you to view. Hope this helps and thanks for using 2CarPros.
and
https://www.2carpros.com/articles/engine-idles-too-high
Sep 29, 2018 at 8:47 PM
JUDDYZAD23
Only this throttle body if I turn the AC comes to low 400 rpm if turn off the AC comes to normal 800 to 900.
Sep 29, 2018 at 9:54 PM
DANNY L
  • 5,648 POSTS
Hello again.
Is this what the throttle body on your car looks like? What size is the engine?
Danny-
Sep 29, 2018 at 10:10 PM
JUDDYZAD23
1.6 Chevrolet Optra 2004.
Sep 29, 2018 at 10:25 PM
DANNY L
  • 5,648 POSTS
Hello again.
I have attached a picture of what the Idle Air Control Valve looks like. Do you see this located on your throttle body? I have also attached a relearn procedure. Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 30, 2018 at 1:44 AM
JUDDYZAD23
Thanks for advice worked perfect!
Sep 30, 2018 at 2:48 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks for using 2CarPros.
Danny
Sep 30, 2018 at 4:26 AM
ROSSZAISTER
Hi. I'm driving 2004 Optra 1.8LT Automatic. Last time I'm having the problem with fluctuated RPM during cold engine. So I brought the car to the workshop and they clean-up my throttle body (disconnect all parts related including IAC, all socket and tube) and the problem been solved
But I'm having new problem day after that. For the past 7 years, my RPM only at 800 rpm at all conditions (either when I put on gear parking/neutral or stop at traffic light and change it to neutral). But currently, the RPM high up to 2000 rpm during parking/neutral, especially when i change my gear to neutral while engines running/waiting at traffic light, or waiting my sons at his school.
How to solve it? I want it back as before, at 800 RPM. Idle Air Control Valve problem? Throttle position sensor problem?
Mar 14, 2019 at 10:36 AM (Merged)
Start by cleaning out the IACV and see what happens
ROSSZAISTER
Thank you. Will do as per advice.
FIXITMR
  • 9,990 POSTS
no CEL?
FIXITMR
  • 9,990 POSTS
may need computer re program of throttle functions.
