I have the car listed above with a 250 straight 6. The motor will idle fine but when I accelerate it shuts off. It acts like it's starving for gas. I've changed the fuel pump and installed an electric fuel pump. I mounted it right next to the tank, as I read it was better closer to the tank. I replaced the fuel filter as well and still no change. If I put it in neutral it will rev just fine but as soon as I put it under a load it stalls. I tried to make adjustments on the carb but it doesn't solve the problem only make other things like idling worst. Does anyone have any answers? I'm pulling my hair out over here. Thanks
Mar 8, 2007 at 6:56 AM
