How to remove the transmission?
1987 CHEVROLET NOVA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
DNOYEZ74119
How do you remove the transmission? Does the engine need to come out?
Mar 25, 2008 at 2:06 PM
MMPRINCE4000
  • 8,548 POSTS
No, generally you suspend the engine on a support fixture, remove axles, mounts, any wiring to the transmission, cables, torque converter bolts, housing bolts etc. and remove the transmission from the side.
Having said all that, I like to remove the entire engine/transmission from the top. A lot more work, but you can change other things (front and rear main seals, axle seals, water pump for example) a lot easier and give the assembly a closer inspection than you could with it in the car.
Mar 31, 2008 at 6:47 AM
