This car is just like a Toyota Tercel, the engine even bears a "Toyota" label. My temperature problem is an intermittent, on again/off again problem. I purchased the car about 5,000 miles ago and when it would not warm up past a lukewarm temp, I replaced the thermostat. However the problem was only partially resolved. It did seam to improve for a time. Occasionally, the heater core makes gurgling sounds. I did think I had an improvement in the problem for a time after traveling on some steep hill roads. Most recently, it actually over heated while idling for an extended time.
Your help is appreciated.
Theresa
Theresa
Mar 31, 2010 at 3:22 PM
