ok so i have pulled the head off and replaced the head gasket putt the head back on torqued the head back on. so now what?
May 9, 2010 at 2:44 PM
HMAC300
CERTIFIED EXPERT
bring each cylinder up to TDC the adjust your valve lash to zero. Once you have that , and that means the push rods should still be able to slightly spin, adjust 3/4 to 1 turn down. Of course if they are solid lifter then you need to adjust it to the specs of the cam that is in the engine.
