Engine Mechanical problem
1966 Chevy Nova V8 Two Wheel Drive Automatic
been working cars for over 25 years
here is the problem customer has a 66 nova ss
it has a 383 stroker motor
he has been chewing up flex plates
i put in a new high per flex plate 168 teeth
he have me a starter that is high per that is supposto match up
problem is that the starter gear wont in gauge the flywheel
it just touches the flywheel
what could the problem be the block has stagering mounting holes and it also has straight in line mounting holes
have tried the stagering starter
have tested to see where the starter gear is hitting
pulled all the way out it barly gos into the teeth of flywheel
i did not build this motor
dont know what to do and he wants the car fixed
should i try a in line starter
Oct 16, 2008 at 4:13 PM
