1965 Chevy Nova overheating
1965 CHEVROLET NOVA
170,000 MILES • V8 • 2WD • AUTOMATIC
NOVA1965
I have a 1965 chevy II nova 283, has new water pump, new 4-core radiator,new 160 thermostat and its running at 210 and will not come down, could i have a cracked head gasket by any chance?
Mar 12, 2008 at 7:14 PM
MMPRINCE4000
  • 8,548 POSTS
How are you measuring the temp? Are you using the temp gauge? It is mechanical or electrical?
Run a compression test for the heads.
A 4 core should be more that adequate for a small block.
Also check you timing and make sure it is not running lean.
Mar 31, 2008 at 6:55 AM
