1963 Chevy Nova oil pressure
1963 CHEVROLET NOVA
3,500 MILES • V8 • 2WD • MANUAL
TROUBLE4U2
engine sounds and runs good but oil pressure gauge only shows 10lb maximum revs up to 4000rpm Tried two different mech. gauges... Changed oil and filter
Jun 26, 2010 at 3:11 PM
Do an engine flush don't work probable causes could be excessive engine bearing clearances or pressure relief valve
Jun 26, 2010 at 3:26 PM
TROUBLE4U2
This is a 2 year old GM Crate engine with 3500 miles on it, In a 1963 SS Nova Convertible, Problem started about two weeks ago, Seems like the oil pressure went from an average of 35 - 45 lbs on the highway to 5 - 10 lbs of pressure at 65 MPH, again engine seems to run fine just very low pressure. Tested it with a mechanical oil gauge under the hood, Same reading!!changed the fittings, used a different guage (New AutoMeter gauge) What's up??? Headed to Columbus GoodGuys July 9 10,11 .any ideas???????????
Jun 26, 2010 at 5:11 PM
Is this from the mechanical gauge or the oil gauge indicator-try replacing the gauge.
Any engine knocking noises of any type-maybe we should try the oil pressure sending unit and see what happens
Jun 26, 2010 at 5:50 PM
