I just bought the car when you try to give it to much gas it sounds like it is sucking alot of air and hesitates for a couple seconds then stops even when in park if you hold your hand real close over the carb the response is right there,every once in a while it pops back. I noticed some sediments in the filter,also i am not sure if the vacuum lines could be causing any of it the one off the tranny goes to a t and splits to the distributer and the carb,then the one from the choke (plastic round with the metal plunger) goes from itself tothe other side of the carb
Sep 2, 2008 at 7:57 PM
