1962 clutch
1962 CHEVROLET NOVA
ZACHSS60
I have a 1962 Chevy Nova 400 with a 6cyl. (194) engine and 3 speed manual. I took a 9in clutch off, but all the parts stores have for this car are 10in clutches or larger. The 10 in I have seems to fit except the holes do not line up with the flywheel. Does anyone know what's up or what part I should be looking for?
May 29, 2007 at 3:17 PM
MIKE H R
  • 3,094 POSTS
the standard clutch for a 62 6 cyl engine is a 10 inch clutch. special order can get a 9 inch clutch. you say that the bolts don't line up , which bolts? The ones holding the pressure plate on? Check the pressure plate you took off and compare it to the 10 in one see what the diference is and let me know..
Aug 21, 2007 at 10:02 AM
