Traction control light and ABS light stays on, brakes have a vibration and a grinding sound
CHEVROLET MONTE CARLO
BECK-KEY
I have the SS model. My service traction control light is staying on, along with the ABS light. It makes a grinding sound along with vibration every once in while, when you hit the brakes. I put new brakes on the back and front. Checked all the fluids. I even hooked it up to a computer. It has 53,000 miles, with a V6. I still cannot find the problem. help
Mar 2, 2007 at 4:01 PM
NUMBER_19_526
  • 5 POSTS
Check and see if the hub assembly is not bad. The speed sensor is built in to the assembly. The sensor goes bad, leading for the ABS/traction control to activate and always stay on in the info center in the car. Hope this helps. I had the a similar problem has to replace to hub due to the bad sensor.
Here is a video to help you to tell which sensor and hub is bad:
https://youtu.be/rTtAnsOlZU4
If you do not have a scanner try this.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Cheers
Oct 31, 2007 at 7:47 PM
MACHEDBERG
I had this problem as well had to replace the right front hub with sensor. Here is the guide I followed:
https://www.2carpros.com/articles/bearing-hub-replacement
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Jul 19, 2018 at 6:24 PM
