timing chain settings
CHEVROLET MONTE CARLO
C.A.COSTA
1999 Monte Carlo 99,000 miles 3.1
my kid was driving it and it started to rap real load and stalled, I went and towed it home.. It will start if you hold the gas to the floor.. But raps real loud.. sounded like vaulve rap... So I did a compression check, only did 3 cylinders but I had zero thirty and ninty.. So I figured timing chain sliped.. I opened the timong case and chain has a little slop not that bad, teeth seem all ok.. I want to make sure it didnt slip, I found the dot on the bottom shaft, but where is the mark on the top?? there are three slotts in the sprocket and a single round hole about a quarter inch round, but no dots, is it the hole that should be at six while the dot is at 12???
Jul 16, 2007 at 8:09 AM
2CARPRO JACK
  • 11,533 POSTS
Looking at front of engine cam pin should be at 3 o'clock with hole in sprocket straight down.Crank key should be at 11 o'clock with mark straight up
Jul 16, 2007 at 12:27 PM
