Checking the altenator with a multimeter,i have 12.8 at the bat lug on the back of the alt. as well as the number two port,with or without the key on, have voltage at the number one port with key on only,but sometimes it is as low as 2 to 3 volts,or as high as 14.4 volts.With the car running on the fast idle solenoid it will continue to run with the battery disconnected,but as soon as you kick it off the fast idle solenoid it will die.Would this reflect a voltage regulator is going away,dont have the info to check the diode bridge or the rectifyer.
Nov 19, 2006 at 10:08 PM
