2004 Chevy Monte Carlo wiper motor index
2004 CHEVROLET MONTE CARLO
JR-MOTORSPORTS
How is the wiper motor indexed? Intermittent wipers pause at top, not bottom.
Feb 11, 2010 at 2:48 PM
SERVICE WRITER
  • 9,123 POSTS
The wiper contriol module that is oin the wiper motor controls it. IT will need the module. I would buy it with the motor and module as one unit. It is probably giving the worng signal to the multifunction switch.
Windshield wiper DELAY operation is a low speed wiper motor function with a variable delay interval between the wiper motor cycles. The DELAY interval is controlled through a series of resistors within the wiper/washer switch. During DELAY wiper operation the wiper switch signal 2 circuit is at the same voltage level used for LOW operation, but the wiper switch signal 1 circuit voltage is reduced through the DELAY resistors. The windshield wiper motor module uses a capacitor feed by the wiper switch signal 1 circuit to determine the frequency of the low speed wiper motor cycles. When the wiper switch signal 1 circuit is at the accessory voltage level as in the LOW switch position, the capacitor charges fast causing continuous low speed wiper motor operation. The DELAY switch position indicating the longest interval between wiper motor cycles is the switch position with the highest resistance resulting in low voltage on the wiper switch signal 1 circuit. The low voltage charges the capacitor slowly causing a long delay interval between wiper motor cycles. As the DELAY switch is turned to positions indicating more frequent wiper cycles, the resistance through the wiper/washer switch is reduced and the wiper switch signal 1 circuit voltage increases. When the wiper switch signal 1 circuit voltage increases the capacitor charges faster and the delay interval between wiper motor cycles decreases.
Feb 11, 2010 at 3:06 PM
