2003 Chevy Monte Carlo Windshield washer pump
2003 CHEVROLET MONTE CARLO
JJGROVE
2003 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
My washer pump is not working. Where is it located. Is it something that a mechanically inclined novice can repair or replace. How can I check to see if it is working.
Dec 17, 2008 at 8:25 PM
MIKE H R
  • 3,094 POSTS
thewasher pump is located by the washer fluid on the bottom of the resevoir. When you turn it on do you hear it trying to work? You could have clogged nozzles and if its cold out, {below freezing} the pump could be frozen if you had just used water instead of windshiel washer fluid that wont freeze. you can check it using a static tester. Unplug the electrical connection and see if you have power to it when you turn the washer pump on.
Dec 22, 2008 at 10:13 AM
