The transmission hangs in first gear and the rpm's go really high. You have to let off the gas completely and let the car idle along and it will change into second gear within thirty seconds or so. The problem seems to be worse when the car has been parked overnight. Once it has been driven for a few miles the problem usually does not happen again until you park it and get back in. All other gears change out smoothly. Please help!
Apr 2, 2008 at 11:51 AM
