2002 Chevy Monte Carlo engine idle
2002 CHEVROLET MONTE CARLO
120,770 MILES • 6 CYL • FWD • AUTOMATIC
CNYSTROM
I just had my catalytic converter cleaned out...it was plugged. Now he car idles arond 1500 rpm, it used to idle around 1000. is there anyway to adjust the idle down?
Nov 29, 2008 at 4:27 PM
RENAUDTN
  • 636 POSTS
You can't adjust the idle speed. It's adjusted automatically by the pcm.
High idle could be the result of a sensors not working properly, or a vacuum leak.
You may need to have your car checked for what's causing the high idle condition.
Do you have any trouble code?
Nov 29, 2008 at 8:31 PM
