2002 Chevy Monte Carlo abs and traction control
2002 CHEVROLET MONTE CARLO
45,000 MILES • 6 CYL • FWD • AUTOMATIC
RMRANGER
Both lights are on...the brakes are new..the abs light and service traction control light are on..I dont think our mechanic knows much about that and I was told if i went to a dealer it could be a small fortune..Only 45000 miles and not driven in the winter..From the internet some say that its usually the sensors but they change those and it comes back on in a week or so...Any suggestions on what to do or where to take it? thanks rick k.
Dec 2, 2009 at 9:40 AM
Hi:
The two systems work together, so you need to identify which sensor is actually bad. Have you had the computer scanned for codes? Most parts stores will scan it for free. Try that and let me know what you find.
Dec 5, 2009 at 6:58 PM
RMRANGER
I did a scan and it came back improper ground...I sanded and cleaned the ground contact..There was no rust or corrosion and the warning hasnt come on in 3 days...Cant believe this could be an easy fix like that...will let you know if anything changes..rick k. thanks
Dec 5, 2009 at 11:02 PM
