2001 Monte Carlo LS intermittent window
2001 CHEVROLET MONTE CARLO
RONK
A slim jim was used to unlock the driver's side door. Since then the interior light won't come on when the door is open, the radio used to shut off when the door was opened - it no longer does. Most annoying - the driver side window goes down fine, but it goes up intermittently. I took the door apart and i found no damage to the switch or wiring harness. What does the down window switch and interior light have in common (ground wire?). Any suggestions??
May 29, 2006 at 6:46 PM
I have an 01 Monte SS and had this same problem. It turned out to be the window switch in the drivers door. Had the same symptoms. Be prepared, at the dealership... this switch will cost you about $60.
Apr 19, 2007 at 6:36 AM
