2001 Chevy Monte Carlo
2001 CHEVROLET MONTE CARLO
BABYWALTON90
Engine Mechanical problem
2001 Chevy Monte Carlo Automatic 100465 miles
Can a monte carlo lock the engine up if more oil was added then needed
Apr 11, 2009 at 6:20 PM
EUGENE123
  • 273 POSTS
no it won't lock the engine up, however adding to much oil is not good for the car because the oil pan is only supposed to hold so much oil and if you exceed that you put a strain on it and it may start leaking you may also have excess oil shooting up around your valve cover pans where you add oil and it may leak there. if you added to much oil simply drain out the excess amount
Apr 15, 2009 at 11:00 PM
