2000 Chevy Monte Carlo oilpan replacement
2000 CHEVROLET MONTE CARLO
TILO1968
Engine Performance problem
2000 Chevy Monte Carlo Front Wheel Drive 111000 miles
what is the cost to replace an oilpan that has a small leak? And who would you recommend? Can one of you guys fix it? It is hard to find someone I trust that will repair my car and not overcharge me.
Oct 9, 2009 at 2:56 PM
Where is it leaking from? And I'm sorry, but you are most likely a thousand miles away from me.
As far as the cost, the job calls for 4.6 hours labor. Times that by the labor rate in your area. As far as a new oil pan, the original equipment one will be in the area of 190.00 and the gasket around 70.00.
NOTE: I'm sure you could get an oil pan from a salvage yard for under 50.00 and an aftermarket gasket kit for about 30.00 from a parts store.
Oct 26, 2009 at 10:12 PM
