2000 Chevy Monte Carlo ABS LIGHT AND CALIPER REPLACEMENT
2000 CHEVROLET MONTE CARLO
GRUMPYDAD71
Brakes problem
2000 Chevy Monte Carlo 6 cyl Automatic 115000 miles
THE ABS LIGHT HAS RECENTLY COME ON IN MY VEHICLE. I KNOW THE SYSTEM NEEDS SCANNED TO GET TO THE ROOT OF THE ABS PROBLEM. I INTEND THOUGH, TO REPLACE CALIPERS,ROTORS, AND BRAKE PADS ON THE FRONT OF THE VEHICLE. WOULD I BE ABLE TO DO THIS FIRST, AND BLEED THE SYSTEM, OR WILL I HAVE TO WAIT AND HAVE THE ABS PROBLEM FIXED FIRST? I RECENTLY BOUGHT ALL NEW PARTS TO DO THE BRAKES, AND I CURRENTLY DO NOT HAVE THE EXTRA FUNDS FOR THE ABS FIX.
Jul 12, 2009 at 4:00 PM
THe light indicates that the system isn't working. However, your brakes should still be fine other than the ABS system. I don't see why replacing the brakes, calipers and rotors will hurt. As far as the light, chances are one of the sensors at the wheels has a bad connection, the wiring has been damaged or the sensor has failed.
Jul 18, 2009 at 4:25 PM
