i've changed the thermostat, flushed the system out, put new coolant in, replaced the radiator cap, i thought to change the temp. sending unit. also could it be that i bought a bad thermostat? it seems as though the car has heat whenever it wants. sometimes it works and sometimes it doesn't. i notice that the upper radiator hose gets hot but the lower hose doesn't get hot its pretty much cold. i'm going to try flushing the core. also i do not have any wet spots on the floorboard to indicate leaking core.
Nov 17, 2008 at 9:45 AM
