1998 Chevy Monte Carlo Not Blowing
1998 CHEVROLET MONTE CARLO
GTHEPEST20
Air Conditioning problem
1998 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
Hi, I am having problems with my air conditioner. When I turn it on, it doesnt blow as hard as it's supposed to. Also, instead of coming through the main vents, it gets redirected to the defroster and feet vents. What do you recommend to fix this problem?
Thanks,
Fernando
Aug 4, 2008 at 3:02 AM
RHALL77
  • 3,361 POSTS
sounds like it went into a default mode. do you have automatic temp controls.
Aug 4, 2008 at 9:32 PM
GTHEPEST20
I have a knob that goes from left to right and it starts with "Max AC" then to "AC" then to "AC to the feet" and then defrost, etc... No matter how much I turn the knob to different settings, nothing changes. It still blows air through the feet and defrost vents. I dont think I have automatic temp controls.
Aug 5, 2008 at 9:48 AM
RHALL77
  • 3,361 POSTS
pull the control head out and see if there is vacuum to the HVAC head. if not thats your problem. then check under the hood and make sure the vacuum line is hooked up.
Aug 5, 2008 at 9:56 AM
