1997 Chevy Monte Carlo My sun roof doesn't open when i try
1997 CHEVROLET MONTE CARLO
CARAMEL_504
Electrical problem
1997 Chevy Monte Carlo 6 cyl
when i try to it clicks as if it's off track.
Feb 25, 2009 at 3:52 PM
3MONTECARLOS
It sounds like the motor is getting current so I imagine, as you do) the window has either gone off track to the side or it's gone too far back and gone off track that way.
Measure the distance from the right side of the window and the left side of the window to the front of the opening--see if it's square. If they're unequal, it's off track to the side. If the two measurements are equal, it may be off track to the rear.
You may be able to "help" it back on track by pulling on it gently as you active the switch. If you can get it back on track it should work but try not to put it so far back from now on. Much cheaper than fixing it!
Good luck
Mar 4, 2009 at 12:09 PM
