The problem usually starts after I have driven it for awhile.I will be driving 60 mph or a steady speed where overdrive is in play, and then try to speed up a little bit and then it will surge back and forth. I can kick it in the arse and it will stop surging until I'm going a steady speed and try to slowly increase the speed. I have replaced the EGR,TPS,Wires,Plugs,Fuel Filter,Main Computer.cleaned out the port under the egr because it was clogged completely.The surge doesn't feel like the tranny is slipping.I'm not getting any codes.This car doesn't have a MAF.Could it be something to do with the torque converter or????? I would say it something to do with my overdrive,but it will do this even if I leave it in drive. any help would be grealtly appreciated.
Feb 3, 2006 at 8:01 PM
