1995 Chevy Monte Carlo Only WorkingTail Ligihts and reverse
1995 CHEVROLET MONTE CARLO
AMPMAN888
Electrical problem
I only have working taillights and reverse lamps, but no headlights. I also cannot seem to find a short anywhere.
Jan 6, 2010 at 2:53 PM
JDL
  • 16,098 POSTS
Hi, did you check voltage circuit At the headlamp? Tan wire is voltage for low beam, Lite green wire is voltage for high beam. Use a testlite on the voltage circuits. I can help you track the circuit,but, you have to do the actual testing. That circuit comes from the dimmer switch. The feed to the dimmer switch is a yellow wire, comes from the headlamp switch. There is a headlamp circuit breaker in the underhood fuse box, check the breaker, use a testlite on the circuit, see if it is hot?
Jan 6, 2010 at 3:56 PM
