the security light came on 4 days ago then went out. car has a remote starter-it was installed by previous owner but works fine. Had some prior starting problems with key. (key has pellet in it. Tried different key same thing. had to wait 5 minutes then car would start. 3 days ago, car stalled on me after starting-like it was out of gas), Did this 3 times. Gas gauge jumps so I figuresd maybe I was out of fuel. Put fuel in. Car ran fine. Parked for the night. Next morning, no start, no crank, no fuel pump noise. All dash lights are on. Checked battery-has 12.05vdc. checked all fuses in panel and under hood- all ok. figured starter burnt out. replaced it-still the same situation. removed remoted starter (just unplugs) from system-same thing. I am at a loss and very low on funds-I can only make a small donation, but if you get me running (I'm old school mechanics, it's the computer stuff that I have difficulty with), I will make a donation of whatever I am able to. Please respond asap. I need to work tomorrow. Thank you.
Jan 1, 2009 at 8:59 AM
