1995 Chevy Monte Carlo Fuel injector fuse keeps blowing
1995 CHEVROLET MONTE CARLO
80,000 MILES • 6 CYL • FWD • AUTOMATIC
MCOWNER95
When I turn the ignition, the fuel injector fuse blows. Car will not start. Fuel pump has been changed, could this be a wiring problem, a relay sensor problem, injector problem? I am at my whitts end with this. Please help.
Jan 1, 2009 at 12:18 PM
JDL
  • 16,098 POSTS
Have you checked for trouble codes? I looked at info for the 3.1. The injectors--hall-effect crankshaft position sensor--camshaft position sensor all share the same voltage circuit. I'd unplug the sensors one at a time, see if the fuse still blows. You might disable the fuel pump, so you don't flood the engine during testing.
Jan 1, 2009 at 12:54 PM
