1995 Chevy Monte Carlo ABS Light
1995 CHEVROLET MONTE CARLO
MAIMEE
  • 7 POSTS
Brakes problem
1995 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
My Anti-Lock light keeps coming on. It only comes on after I've started driving, sometimes right away, some times after I press on the brake, sometimes not at all. When the light is off, the brakes skid, having to pump them. When the light is on, the brakes seem okay. Any clues as to how I fix this?
Apr 30, 2008 at 6:04 PM
SARAHTHEBEAR
My 2001 did the same thing. The front driver side hub bearing has a sensor that can go bad. Get that replaced and your braking and light problem should be fine- might want to get your brakes done while your in there. good luck
Jun 5, 2008 at 9:01 PM
