1987 Chevy Monte Carlo FUEL INJECTION PROBLEM
1987 CHEVROLET MONTE CARLO
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRENTM3
hello, I just bought an 87 monte carlo, but cannot get it to stay running without constantly pumping the gas pedal, I've tested the injectors, the iac valve, the map sensor, egr valve and the pump is pumping fuel. I noticed when we took the vacuum line off of the map sensor it ran quite a bit better, but still wont idle or run real well. We also checked the codes and its shootin a 34 and 35. I did replace the map sensor and it made no difference. I've been through repair manuals also, and i'm just stumped? Any ideas would be greatly appreciated. Thanks, Brent
Jun 20, 2009 at 7:37 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check TPS on terminal A ground volt meter probe terminal B Gray wire should see 5V. Then probe terminal C dark blue at idle less than 1V if good slowely open throttle voltage should increase to 4.5 V WOT With NO fluxuations.
Let me know
Thanks for donate
Also check O2 what is voltage on wire at idle and as you throttle up
Jun 21, 2009 at 1:14 PM
