First post. I was driving to work the other day when the car just kinda shuttered and then died. It would not start. About 30 mins later it started once and ran for about a min and then died again. I had it towed home and worked on it later that night. Using a timing light I found that I was not getting any spark, but also found that I was not getting any fuel. My helper tried it again and then the timing light flickered and then the car started right up. We ran it for about 3 mins and then shut it off and it has not started since then. I checked power to the fuel pump and with the key on, there is only about 7 volts. Still no spark either. I checked all of the fuses I could find and none were blown, but I did find a 7.5 amp ECM fuse (according to stenciling) does not have power on either side. I have changed the computer (ECM) but it did not help. The fuel pump relay seems to work because I can watch the contacts operate. My Haynes manual does not even show this 7.5 amp ECM fuse in the fuse box, so I have no idea where it is fed from. Any ideas ?? It is the 4.3 liter V6 with TBI.
Thanks. Robert
Thanks. Robert
Jul 23, 2007 at 10:17 PM
