1978 Chevy Monte Carlo Headlight dimmer switch
1978 CHEVROLET MONTE CARLO
95,000 MILES • V8 • 2WD • AUTOMATIC
DIAADA
Where is the headlight dimmer switch located and how do I replace it
Nov 29, 2009 at 8:35 AM
I believe the dimmer is part of the switch itself. Do you have a regular pull out headlight switch? If so, when you turn the switch, doe the panel lights dim? If I am correct, and it's been some time since I worked on a 78, the dimmer and the headlight switch is one part.
Let me know. Also, if you need help removing it, let me know.
Dec 5, 2009 at 7:18 PM
