1998 Chevy Metro grinder!!
1998 CHEVROLET METRO
170,000 MILES • 4 CYL • FWD • AUTOMATIC
MILLWRIGHT808
the tranny in my 98 geo metro, 4 door, auto, front wheel drive just popped and now does not move in any gear, it does however make a nice grinding noise...I dont know what the 2 parts of the tranny are called, bell housing and transfer case??
Dec 7, 2009 at 12:35 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This sounds terminal, have the transmission removed & checked out, i would not try to run it as if the oil pump is still working you are sending metal shavings thought the transmission doing even more damage.
mark (mhpautos)
Dec 7, 2009 at 3:10 AM
MILLWRIGHT808
does a guy have to drop the engine to remove the tranny?? doesnt look like there is enough room to remove the spline....
Dec 7, 2009 at 11:38 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, with the drive shafts removed and the engine transmission mounts removed the engine and trans drop down enough to remove the trans only, with an auto there is no input shaft like a manual, the torque converter bolts onto the drive plate so you only have to move the trans back just a small amount to be able to remove it.
mark (mhpautos)
Dec 7, 2009 at 11:55 PM
