2006 Chevy Malibu New power steering rack
2006 CHEVROLET MALIBU
60,000 MILES • 6 CYL • FWD • AUTOMATIC
RUBYRODNEY
I just had a new power steering rack put in today but car still wants to drift all over steering lose at low speeds then tightens at higher highway speeds. I took notice on the invoice I received from the garage that no alignment was done w/ the repair job. Should it have been and could that be the only issue? Also a rattle vibration noise coming through the air vent system in dash at 40 mph they said it was a lose wiper and plastic cawl against the windshield but on the drive home there it was! The car is still under warrenty so I don't want to miss anything!
Jul 28, 2010 at 6:57 PM
DENNYP
  • 1,824 POSTS
You are correct, an alignment should have been performed. It is ,however, normal for these vehicles to have more power assist at lower speeds than at higher speeds.
As for the rattle noise, here is a service bulletin. Make sure the bulletin was followed exactly as it is written.
Subject: Vibration/Rattle/Buzz Noise From Right Front Side of Dash/Windshield Area at Speeds Above 56 km/h (35 mph) (Install Two-Way Tape)
Models: 2006-2007 Malibu, Malibu Maxx
Condition
Some customers may comment on a vibration/rattle/buzz type noise coming from the right side dash/windshield area. The noise will start when the vehicle speeds reach 56 to 64 km/h (35 to 40 mph) and continue up through highway speeds.
Cause
The noise may be coming from the plastic cowl cover screen vibrating and contacting the windshield on the right side of the windshield between the wiper post and the right side "A" pillar. The cover may be raised off the windshield slightly and the air flow as the vehicle is traveling is pushing the cover down, causing the rattle/buzz noise.
Correction
Remove the cowl cover and install a strip of double stick tape to the underside of the cover. Install the tape about 102 mm (4 in) from the wiper post opening to the end of the cover. The tape should be on the plastic cover, not on the seal. Clean the windshield in this area and reinstall the cover. Press the cover down where the tape was installed.
Parts Information
Part Number
Description
3M 06397
3Mâ„¢ Scotch Mount*
Jul 29, 2010 at 11:15 AM
