2005 Chevy Malibu headlights & radio
2005 CHEVROLET MALIBU
ERLE
Electrical problem
2005 Chevy Malibu 4 cyl Front Wheel Drive Automatic
when i turn the ignition off the headlights and radio stay on untill i remove battery cable, when i reinstall the battery cable all is fine untill car is turned on then off again then the problem is back again.
Oct 24, 2009 at 10:23 AM
JDL
  • 16,098 POSTS
Welcome to the forum, You need to check for any codes, manufacturer specific. The headlamp switch sends a request to the bcm to turn on lamps. The bcm grounds the coil side of headlamp relay. If there is a code, it may help pinpoint the problem. I'd have to track the wiring circuit.
Oct 24, 2009 at 11:42 AM
