2005 Chevy Malibu Check engine light and prognosis
2005 CHEVROLET MALIBU
CMMOYA27
2005 Chevy Malibu
Hi, the check engine light recently came on in my 05 Chevy Malibu. I took it to chain Auto Part store and they ran a test and said it needed to be taken to a mechanic. I would like to get a few possiblities as to what the problem could be 1.before I do same. This is what the troubleshooting receipt said:
Definition:
EVAP Flow During a Non-Purge Condition
Explanation:
The ECM has detected pressure in the EVAP system a non-purge condition
Probable causes:
1) Purge or vent solenoid failure
2) Plugegd EVAP canister condition
3) Failed EVAP Pressure Sensor
Oct 23, 2008 at 12:07 PM
TEAG
  • 158 POSTS
First thing you should do is check all the hoses first. Damaged or missing hoses are often the cause of many problems. If thats not the case, the job would consist of Cleaning or replacing the cannister. Check/ Replace the pressure sensor and check/replace vent solenoid. If codes are correct. The problems in there somewhere.
Oct 23, 2008 at 1:18 PM
