Car starts and runs fine except it will die if foot is removed from accelator. With control of the accelator, I can get the RPMs down to 600 RPM. There is no check engine light "on".
May 23, 2020 at 1:50 PM
(Merged)
CERTIFIED EXPERT
Inspect and test the idle air control valve and throttle position sensor, PCV and EGR valves-
May 23, 2020 at 1:51 PM
(Merged)
DARIN_M66
MEMBER
It was the dirty throttle bore. Thanks
(Merged)
JENNIFER LYNCH
MEMBER
1 POST
car turns over and starts, but it will not stay running.
(Merged)
JIS001
CERTIFIED EXPERT
Clean the throttle body and idle air control valve. The valve is attached on the throttle body. If that does not work then replace the idle air control valve.
Image (Click to enlarge)
(Merged)
BULLETSPONGE62485
MEMBER
When the vehicle is at idle it dies. We hooked the car up to a computer and produced no codes. Any suggestions as to what could be making it die? It starts right back up after it dies but will die a lot when it is at idle.
(Merged)
RHALL77
CERTIFIED EXPERT
i there a security light blinking. check and see if you are loosing fuel pressure or spark
