2005 Chevy Malibu air conditioning leaking
2005 CHEVROLET MALIBU
61,000 MILES • 6 CYL • FWD • AUTOMATIC
REDWNG30
I go this car used and everything was fine for a week then i noticed when i got it to Arizona and started running the air constently it starting leaking from under the dash especially when i make left turns. I took off the protective shield behind the glove box and stuck my head under the dash while my wife drove(as this only leaks while driving) and noticed its coming from the hole on the bottom of what looks like the fan casing for the ac. I dont understand why there is so much condensation but there is alot with 4 hard left turns the passenger floor has 2 inches of water. What can i do to remedy this?
Aug 25, 2009 at 12:48 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This is normal, apart form it collecting on the floor, the A/C dehumidifies the air (removed all the moisture) this normally drains away via a drain tube, this tube will be blocked, i am not sure where they are located on your car, but a dealer will point it out in a second.
Mark (mhpautos)
Aug 25, 2009 at 5:30 AM
